Disable an ACL
Perform this procedure to disable an ACL and all ACEs that belong to it.
Variable definitions
Use the data in the following table to use filter acl command.
Variable |
Value |
<1-2048> |
Specifies the ACL ID. |
enable |
Enables the ACL state, and all associated ACEs. Enabled is the default state. |
matchType <both|terminatingNNIOnly|uniOnly> |
For inVsn ACL types, specifies the match type to associate with
the ACL. Valid options are:
The default value is both. |
name WORD<0-32> |
Specifies an optional descriptive name for the ACL. |
type <inVlan|inPort|outPort|inVsn> |
Specifies the ACL type. The values inVlan, inPort, and inVsn are ingress ACLs, and outPort is an egress ACL. A port-based ACL has precedence over a VLAN-based ACL. |
